You can purchase an off the car inexpensive injector cleaning kit (about $20) that works with a can of carburetor cleaner. It will also show if the injector is clogged or spraying.
I usually clean the injectors while on the car with a more elaborate pressurized system but this simple cleaner/tester will work fine.
"THE COLUSSUS" 87GT - ALL OUT 3.4L Turbocharged engine, Garrett Hybrid Turbo, MSD ign., modified TH125H
" ON THE LOOSE WITHOUT THE JUICE " [This message has been edited by Dennis LaGrua (edited 09-18-2019).]
