  Anyone ever wrapped their hood or decklid with real carbon fiber.
Anyone ever wrapped their hood or decklid with real carbon fiber. by hercimer01
Started on: 09-17-2019 04:47 PM
Replies: 7 (296 views)
Last post by: Iain on 09-26-2019 11:28 AM
hercimer01
Report this Post09-17-2019 04:47 PM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
Glue it on then glazed it with resin? I'm toying with the idea.
12.840@104.8 MPH Intense-Racing 1.9 rockers, 3" exhaust, 3.4 pulley, ZZP tune and 18 year old tires.
88 Coupe under construction SOLD
88 formula 3.4L 4t60 swap SOLD
88GT resurrection in progress.
hercimer01
Report this Post09-20-2019 02:11 PM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
Bump
Total ratings: 205
Report this Post09-20-2019 02:24 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Carbon fiber requires good respiratory and skin protection to handle.
The manufacturing process is much more involved than 'lay it out and glaze with resin', requiring vacuum and temperature to fully wet, penetrate and cure.
Many of the vinyl wraps will look like real carbon fiber, and be much easier and safer to work with.
hercimer01
Report this Post09-20-2019 04:16 PM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
The process of wrapping it and glazing has been used a lot on smaller things like trim panels and mirrors. I know it can be done, I was just wondering if anyone has ever done larger things.
Iain
Report this Post09-25-2019 06:21 PM Click Here to See the Profile for IainSend a Private Message to IainEdit/Delete MessageReply w/QuoteDirect Link to This Post
You're quite right, carbon, or any fabric really, can be wrapped, or skinned, or laminated, whichever terminology floats your boat, onto almost anything.
Problem is, the fabric comes in a roll that's narrower than most bonnets/hoods. The seam is difficult to hide, or get neat, so is commonly hidden by a painted or vinyl stripe, even seen a contrast fabric used. It's something I'm practicing at the moment as I'm remaking my bonnet and engine cover. It is Not at all Easy.
You do NOT need vacuum/pressure or a heating process for skinning. That's for prepreg, which no one in their right mind would use for skinning. You can use vacuum consolidation for skinning, it's not usual though, I've only used it to laminate heavy weight fabrics to skateboard decks.
The only thing you've been told that's correct is eye/lung protection, that's the same for any cutting/grinding/sanding operation.
There are 2 big problems.
1. It has to be considered permanent. You can recover metal parts, but plastic/wood etc, no chance.
2. It would be expensive. There would be almost as much waste as you'll use. Assuming you go with a centre seam. You also need carbon shears to cut it. You will NOT cut the fabric with dressmaking shears! You would need 140-200 g fabric, anything else is a bit heavy. There are fabrics specifically manufactured for skinning, which have extra binders in to prevent distortion, or weave separation. The weight corresponds to thickness, not added weight on the panel, the heavier the fabric the thicker it is, the harder it is to conform it to curves/edges/detail. YOU WOULD HAVE TO USE AN EPOXY RESIN AS THE BASE LAYER! And key the surface like crazy.
I use black diolen, it looks exactly like a superfine carbon, it's lighter in weight, generally 120-200g per metre so it's very easy to use and it's a 1/4 of the price. Only someone experienced will know it's not carbon. You can, just, cut it with dressmaking shears. I plan on covering most of my panels as it's cheaper than paint.
Or, carbon/black twaron, twaron is the generic name for kevlar which is a DuPont trademark. Carbon isn't really black, it's brown/grey, c/bt really pops because there's much more contrast, the coloured twaron is super black. As a decorative finish, it's on another level. Half the cost of carbon, but you need carbon or twaron/kevlar shears to cut it, you'll just make a complete mess with anything else.
As an aside, if someone suggest you use 'coloured carbon' as it's lighter and easy to use, that's because it's a polyester fabric. You can't dye carbon. Though you can get black/coloured fabrics where the black is actually carbon, generally a higher cost.
Have a look at www.easycomposites.co.uk ( it's who I get my stuff from now, I have no connection with them) they have some great instructional videos, both on their site and youtube. Have a look at the rifle they did for one of the UK Olympics, that's pretty much what you need to do. I have one to do soon for a colleague.
Black Base layer
Lay fabric at tacky stage
Allow to cure
Wet out and allow to cure
Flat and repeat.
Flat and polish.
If you use a stripe you can epoxy over it to give a smooth surface once flatted. If you ever use a polyester resin you need to check beforehand that it won't dissolve the stripe, as one of my friends discovered the hard way ;-)
Regards, iain
[This message has been edited by Iain (edited 09-25-2019).]
Total ratings: 205
Report this Post09-25-2019 07:27 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Good post, lots of information.
Thanks for sharing!
hercimer01
Report this Post09-25-2019 11:08 PM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
Regards, iain
Thanks!
Thanks for the write up!
[This message has been edited by hercimer01 (edited 09-25-2019).]
Iain
Report this Post09-26-2019 11:28 AM Click Here to See the Profile for IainSend a Private Message to IainEdit/Delete MessageReply w/QuoteDirect Link to This Post
And I'm completely wrong, you guys are better catered for over there, fabric is available much wider (and cheaper) than we get here in the UK.
https://www.fibreglast.com/...530/carbon_fiber_all
50" (!) is far wider than i can source, they also do a 42" wide fabric which is more than wide enough for the bonnet/engine cover.
min length is 10 yards it says, but I'm sure if you asked nicely they could sort you out, or point you in the right direction.
