  O-ring for throttle body 2.8
O-ring for throttle body 2.8 by go faster
Started on: 08-28-2019 07:04 PM
Replies: 6 (196 views)
Last post by: fierofool on 08-29-2019 06:15 PM
go faster
Report this Post08-28-2019 07:04 PM Click Here to See the Profile for go fasterClick Here to visit go faster's HomePageSend a Private Message to go fasterEdit/Delete MessageReply w/QuoteDirect Link to This Post
Working on vacuum leaks would like to know the size of the o-ring for large metal line at the bottom of the throttle body. Did a check with smoke and had some smoke leaking from that line. Any help would be great. Did a search no information was available.
fierosound
Total ratings: 287
Report this Post08-28-2019 07:28 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
P22 Parts book...
3.336 O-ring, vacuum tube PN 10039067
There's nothing special about it though.
You can take it out and match it up to a regular black o-ring (most likely a metric size)
go faster
Report this Post08-28-2019 07:32 PM Click Here to See the Profile for go fasterClick Here to visit go faster's HomePageSend a Private Message to go fasterEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks a bunch. Will try that.
go faster
Report this Post08-28-2019 07:43 PM Click Here to See the Profile for go fasterClick Here to visit go faster's HomePageSend a Private Message to go fasterEdit/Delete MessageReply w/QuoteDirect Link to This Post
go faster
Member since May 2003
tazome
Report this Post08-29-2019 02:01 PM Click Here to See the Profile for tazomeSend a Private Message to tazomeEdit/Delete MessageReply w/QuoteDirect Link to This Post
just replaced mine ) i got a box of metric orings from harbor frieght, alot of people forger to replace that one along with the line under the plentum, replace those plastic line with the stainless metal ones , you would be surprised how brittle the are
go faster
Report this Post08-29-2019 02:37 PM Click Here to See the Profile for go fasterClick Here to visit go faster's HomePageSend a Private Message to go fasterEdit/Delete MessageReply w/QuoteDirect Link to This Post
I did that but the car was down. Ready to get it back on the road if all the vacuum leaks are sealed.
Total ratings: 154
Report this Post08-29-2019 06:15 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just sent an O-ring to a fellow club member. The inside diameter of the ring is 0.543 inches and the thickness of the ring is 0.10 inches.
