  Code 33 and 42 in my turbo 3.4 Fiero
Code 33 and 42 in my turbo 3.4 Fiero by Madess
Started on: 08-02-2019 09:42 AM
Replies: 7 (358 views)
Last post by: Madess on 10-21-2019 07:12 AM
Madess
Report this Post08-02-2019 09:42 AM Click Here to See the Profile for MadessSend a Private Message to MadessEdit/Delete MessageReply w/QuoteDirect Link to This Post
Code 33 MAP sensor circuit error (signal high indicating low vacuum)
Code 42 Ignition bypass circuit error
I am getting these two codes as soon as I start my Fiero. It is a 3.4 Turbo with a 7730 with a chip from Ryan. I put another MAP sensor on it, and it does the same thing. Am I using the wrong map sensor? I am using one from a 1980's turbo Sunbird.
Thanks for any help.
Total ratings: 237
Report this Post08-02-2019 09:50 AM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sounds like you have wiring problems.
Distributor or DIS? Iron head?
[This message has been edited by Will (edited 08-02-2019).]
Madess
Report this Post08-02-2019 10:10 AM Click Here to See the Profile for MadessSend a Private Message to MadessEdit/Delete MessageReply w/QuoteDirect Link to This Post
DIS, iron heads.
Total ratings: 237
Report this Post08-05-2019 11:36 AM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
Having something pinned incorrectly could cause one or both problems.
lou_dias
Total ratings: 67
Report this Post08-07-2019 08:04 AM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
When I had my 7730 done and I started swapping sensors from other cars, occasionally I'd have to swap the power and ground wires on the connector. This happened when I used the TPS from an F-body. Your map sensor may have the same issue. It may be on the same circuit causing your code 42.
Madess
Report this Post08-17-2019 12:05 PM Click Here to See the Profile for MadessSend a Private Message to MadessEdit/Delete MessageReply w/QuoteDirect Link to This Post
I got the code 33 to go away, but the code 42 is still there. Could the ignition module be bad?
[This message has been edited by Madess (edited 08-17-2019).]
Report this Post08-17-2019 12:42 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Always a possibility. Examine the connectors and wires too. Spark plug wires touching each other can trip a 42.
Madess
Report this Post10-21-2019 07:12 AM Click Here to See the Profile for MadessSend a Private Message to MadessEdit/Delete MessageReply w/QuoteDirect Link to This Post
It was a bad spot in a wire. Found it and reattached it, and all is working well.
Thank you
