  WHICH TEMP SENDER ?
WHICH TEMP SENDER ? by Lou6t4gto
Started on: 07-17-2019 01:46 PM
Replies: 5 (171 views)
Last post by: Lou6t4gto on 07-20-2019 04:49 PM
Lou6t4gto
Report this Post07-17-2019 01:46 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
which temp sender is for the ecm ? the head, or the filler neck ? Thanks
Total ratings: 154
Report this Post07-17-2019 01:54 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
It's the sender with the oval head.
Total ratings: 568
Report this Post07-17-2019 02:01 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
And if you buy one... will need to splice a new Metripak plug to use it.
Years ago GM and others no longer make the old one.
Solder and shrink tube is best for ECM reading this accurately.
Total ratings: 154
Report this Post07-17-2019 08:52 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm pretty sure the L4 uses the same sensor as the V6 and both the Coolant Temperature Sensor (ECM) and the gauge/light temp sensor are still available. The CTS for the ECM is in the thermostat housing and the gauge/light sensor is in the head. You shouldn't need to cut and splice harnesses. Autoparts stores often sell the CTS sensor as the one for the gauge/light and they tell you the new design requires a new style harness end. This isn't correct.
https://www.autozone.com/en...sor-su109/146258_0_0
fierosound
Total ratings: 286
Report this Post07-20-2019 04:27 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Temp Sender is for the gauge
Temp SENSOR is for the ECM
Temp Switch is for the fan
The Duke
The V6
[This message has been edited by fierosound (edited 07-20-2019).]
Lou6t4gto
Report this Post07-20-2019 04:49 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
perfect. thanks
