So I finished swapping a 46,000 mile 2.8 V6 into my '85 GT with 100,000 miles (the original V6 threw a rod) last month. The car was running like a champ for around a week (minus an oil leak) and then I dropped it off at BrakeMax to have them pull a stuck front hub off for me. When I got the car back this past Monday, I started it up and noticed that it was running terrible. (I spoke with the manager and the mechanic that worked on my car, and they said they did not touch anything engine-related at all.) It idles around 1000 RPM but is really rough, the engine vibrates quite a bit, and there's absolutely no power. It is so low on power that when I try to start off in first gear or reverse, it comes very very close to stalling. It doesn't rev happily at all, it sounds terrible, and it doesn't seem to have the effort to rev up past like 4k. And if it does, it takes longer than usual to get up there.
I replaced the fuel filter yesterday, but that did nothing. I can hear the fuel pump come on when I turn the key to the "on" position, so I know it's neither of those. So far, I haven't seen any coolant/water in the oil or on the oil cap. I have also flushed my cooling system multiple times. I put straight, clean water in, and flush it out a couple days later, and its very brown or black. I'd say I've flushed at least 4 times, even with BlueDevil radiator flush for two of the flushes.
I know I have the spark plug wires connected correctly, I followed the firing order that I found here on the forum.
At this point, I have no clue what direction to go next, so once again, I turn to the forum. Anyone have any suggestions?
'85 Fiero GT [4-speed]
‘86 4cyl (Parts Car) [5-speed]
'95 Mitsubishi 3000GT VR4 [6-speed]
