  Decklid corner adjustment?
Decklid corner adjustment? by chaotichamster9
Started on: 06-30-2019 09:57 PM
Replies: 4 (192 views)
Last post by: Dennis LaGrua on 07-03-2019 07:43 AM
chaotichamster9
Report this Post06-30-2019 09:57 PM Click Here to See the Profile for chaotichamster9Send a Private Message to chaotichamster9Edit/Delete MessageReply w/QuoteDirect Link to This Post
I’ve noticed the back driver side corner of my decklid is hiked up slightly above the rear quarter panel. The passenger side is just fine and the sides and front and back all appear squared up it’s just this corner that is raised. I’ve adjusted the rubber stoppers and it’s not those so just wanted to know if anyone had a quick solution? Here’s a picture (it is more pronounced in person) Corner
[This message has been edited by chaotichamster9 (edited 06-30-2019).]
Report this Post06-30-2019 10:19 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Try loosening the nuts/bolts on the passenger side decklid hinge, as it is raised up, it could push the rear DS corner down.
Total ratings: 205
Report this Post07-01-2019 07:58 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
As guru suggested.....
Remove the decklid grills and close the decklid, all four of the adjusting bolts on the decklid and the four adjusting nuts on the hingeboxes are then easily accessible.
The grille brackets on the upper strut mounts are also adjustable.
[This message has been edited by olejoedad (edited 07-01-2019).]
Tha Driver
Total ratings: 204
Report this Post07-01-2019 09:50 PM Click Here to See the Profile for Tha DriverClick Here to visit Tha Driver's HomePageSend a Private Message to Tha DriverEdit/Delete MessageReply w/QuoteDirect Link to This Post
Can you push down on the decklid at that corner to make it flush with the 1/4? If the decklid is square in the opening & flush at the back of the 1/4 panels, you probably just need to adjust the latch to pull it down a little tighter.
~ Paul
aka "Tha Driver"
Custom Fiberglass Parts
Total ratings: 328
Report this Post07-03-2019 07:43 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Its a good idea to also adjust the rubber bumpers at the corners of the deck lid. They screw in and out and most often they are broken or worn. Their purpose is to set the final height of the deck against the rear fender and to insure that the lid pops open after the key is turned or latch release is activated. The Fiero Store sells new ones and they are inexpensive. .
