  Large bore vacuum line in throttle body
Large bore vacuum line in throttle body by damittron
Started on: 06-27-2019 06:01 PM
Replies: 8 (229 views)
Last post by: fierofool on 06-28-2019 09:05 AM
damittron
Report this Post06-27-2019 06:01 PM Click Here to See the Profile for damittronSend a Private Message to damittronEdit/Delete MessageReply w/QuoteDirect Link to This Post
I noticed a vacuum leak noise coming from my engine this afternoon, I messed around with things until I finally found it was the large bore vacuum hose (tube?, it is metal) was where the noise was coming from (the one connected to the bottom of the TB). I used a large screw driver and levered it a bit, when it was pushed in a bit, it would seal and the noise would stop, when I let go, it started hissing again. Is there supposed to be some kind of o-ring, seal, or something else that holds this in place? I am going to be pulling the top intake off in a week or so to replace the old vacuum hoses with stainless ones from Rodney, so I woud like to fix this while I'm at it.
TIA,
D.
[This message has been edited by damittron (edited 06-27-2019).]
Total ratings: 154
Report this Post06-27-2019 06:16 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, there is an O-ring inside the back of the throttle body.
Total ratings: 207
Report this Post06-27-2019 06:23 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
That tube is the air feed for the IAC.
damittron
Report this Post06-27-2019 06:39 PM Click Here to See the Profile for damittronSend a Private Message to damittronEdit/Delete MessageReply w/QuoteDirect Link to This Post
AH-HAH! Thank you sir!
damittron
Report this Post06-27-2019 06:42 PM Click Here to See the Profile for damittronSend a Private Message to damittronEdit/Delete MessageReply w/QuoteDirect Link to This Post
damittron
Member since May 2018
AND...Thank you as well! I wish you guys were in Florida, I would buy you both a beer!
Total ratings: 207
Report this Post06-27-2019 07:27 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm on my way!!!
Total ratings: 154
Report this Post06-27-2019 09:37 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'll have to take a raincheck. I just made the trip to Carlisle and I'm not up to another trip for a while.
damittron
Report this Post06-27-2019 10:48 PM Click Here to See the Profile for damittronSend a Private Message to damittronEdit/Delete MessageReply w/QuoteDirect Link to This Post
I need to make a good meet-up, but it is a long haul from either Florida or Texas to get to them.
Total ratings: 154
Report this Post06-28-2019 09:05 AM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Run For The Hills isn't far from Florida and if you're in Texas, caravan along with the Swayne Brothers. I believe they're making the treck again this year for RFTH. You'll have a lot of folks to meet up with.
