| quote | Originally posted by Odin:
So the car has a brand new ACDelco EP381 in it. I just had the tank out and replaced all of the hoses/strainer/filter. No kinks, restrictions etc. The pump has submersible fuel hose connecting it to the sending unit. Its holding 55plus PSI through acceleration in the top end. So not sure where to go after this. How do I check the regulator? Would it still hold pressure if the regulator if the regulator was bad? Thanks
Sounds like the FP regulator is working. One sensor very critical to fueling is the MAF sensor. If its dirty, the engine will run lean. I had this problem with a new Delphi MAF sensor that picked up an oil film from a new "permanent" K&N filter. I would try cleaning the MAF sensor with special MAF cleaner. A defective IAT, ECT or O2 sensor can also make the engine run lean. The only way to tell is to do a scan and watch all the sensor readings.
