| quote | Originally posted by Betty67: Out of curiosity I pulled out my oil pressure tester and put it on the car and it read 79 psi which is way too high at idle. |
IOW a mechanical gauge on the engine?
V6 should be 30-45 PSIG Oil pressure should stay within the specified range at all RPM whether the engine is hot or not. In very cold weather, oil pressure may be a bit higher than normal until the engine warms up a bit.
Yes, OP high can be bad. Even if Oil Filter can doesn't bust, the top where it meets the engine can fail and leak or worse.
Often High pressure means:
Oil Pump has problems. Most OP have the regulator in/on them and reg is bad/blocked.
Some fool installed HV/HP pump because they believe BS hype.
