  Release bearing trouble
Release bearing trouble by dma46072
Started on: 06-17-2019 07:48 PM
Replies: 1 (79 views)
Last post by: Patrick on 06-18-2019 12:17 AM
dma46072
Report this Post06-17-2019 07:48 PM Click Here to See the Profile for dma46072Click Here to visit dma46072's HomePageSend a Private Message to dma46072Edit/Delete MessageReply w/QuoteDirect Link to This Post
I had decided to throw about $700 in new parts at my 86 SE V6 and I thought it was going well. After getting most of the parts put on I realized that the release bearing was not installed correctly. Is there a way to service the release bearing without removing the entire cradle? I already put all new fluids in and don't want to lose fluids if I can avoid it. Thank you in advance.
Total ratings: 458
Report this Post06-18-2019 12:17 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sure... loosen the front cradle bolts, remove the rear cradle bolts, and tip the cradle down in the back. This procedure is commonly used to remove the tranny.
