Hi, I recently bought a used Colgan Fiero bra for my 1988 gt. It has been stored for 5 years and has apparently shrunk. Does anyone have directions on how to attach everything. I do not believe it requires any hardware. I am told to wet the bra and it will stretch. Also, maybe putting it in the summer sun might help? Any thoughts or recommendations are appreciated
They made good bras. It is pretty much self explanatory. The rear flap is usually held in by the edge screws of your fascia and fenders. You will need a 7mm socket to remove them. The tabs are made of thin metal and covered with soft material. once all the parts that need to be screwed in are in place, just bend the tabs around the lower fascia. the headlight flaps are in two variants, those that are strapped to the headlight cover and those that you have to "roll-up" and hold in place with velcro.
You are right, placing it in the sun and pulling on it a bit will help loosen it up but it is still designed to be tight.
