I just did a brake upgrade, I swapped from my stock Fiero brakes(which were fine but had a soft pedal) and moved to upgrade Corvette C5 brakes.
I swapped out the booster for an S10 booster and the master cylinder for a larger upgraded one from a blazer as well. For now, I am just upgrading the front discs and calipers.
There was still dirty fluid in the lines for the rear(old brakes), but it seemed I was able to to get those lines bled(no air bubbles, but no clean fluid either).
When it came to the front brakes, I was not able to bleed them. Air came out of the bleeder screws, but no matter how many times my girlfriend and completed the procedure(about 45 times, opening the valve, pushing the pedal then closing the valve and releasing), I never got fluid coming out the front. Also, the level of fluid in the master cylinder never went down at all. I did get increased pedal resistance, but the front brakes are at this point completely inoperable.
Am I doing something wrong? Do I need to run the car with the new brake booster or something? I have bled brakes many times but I have never installed a master cylinder and brake booster.
Did you bleed the new master cylinder first? (Not the calipers)
So, I tried..
I opened up both lines on the MC and attempted to push fluid through, but fluid would only go through the rear hole. When loose or open, the rear port had fluid come out. When loose or open, the front would not let any fluid through.
Normally you bench bleed the master before installing. Mount in a vice, loop the outlet ports to dump into the reservoir, then cycle the master about 10 to 20 times.
Doing this also let's you know if you got a bad one before installing it.
It is also best to figure out the soft pedal issue before swapping parts and you might not be addressing the issue. Soft pedal is air in lines or an out of adjustment rear brake caliper.
Yeah I wanted to do the brake upgrade anyway.
I should be able to take this master cylinder off and bench bleed it at this point right?
MC w/ any "new" Booster of any kind must be adjusted right or MC will not return fully etc. When MC doesn't return to rest position, Either or Both pistons will have problems including bleeding problems.
Have you tried replacing the brake hose? They can collapse internally and cause a blockage.
I would try that, but I bled both front calipers and both front brakes were working before I did the upgrade, the lines themselves barely moved.
I have to take it in for an alignment anyway, I think I will just have the mechanic bleed the system because I am sick of messing with brake fluid in my freshly painted front compartment.
