  3800 - lower manifold coolant plugs? or throttle body spacer with coolant blockoff?
3800 - lower manifold coolant plugs? or throttle body spacer with coolant blockoff? by DimeMachine
Started on: 06-10-2019 12:55 PM
Replies: 7 (711 views)
Last post by: Dennis LaGrua on 06-21-2019 07:32 PM
DimeMachine
Report this Post06-10-2019 12:55 PM Click Here to See the Profile for DimeMachineSend a Private Message to DimeMachineEdit/Delete MessageReply w/QuoteDirect Link to This Post
Question for the 3800 crowd and first hand knowledge.
My air inlet pipe and rubber coupler is getting more heatsoaked than I would like. I see a lot of the GTP crowd plugs the two holes in the lower intake manifold thus blocking coolant flow to the M90 supercharger and throttle body. I am not concerned about winter icing as I do not drive this car in the winter.
If anyone has done this mod, I would be very curious for any observations you have to share as far as supercharger temps and inlet track temps - before and after.
PS. Fiero Video for fun. https://www.youtube.com/watch?v=upkKsxPQqfw&t=0s
Thanks in advance!
Dime.
84/87 NB, 3800SC, E-85, VS Cam, 2.8 Pulley, 4T65E-HD, HP Tuners, AEM Wideband, Regal GS Gauges, S-10 Brake Booster. 1/4 mile -11.85 at 114mph
randy86
Report this Post06-10-2019 01:59 PM Click Here to See the Profile for randy86Send a Private Message to randy86Edit/Delete MessageReply w/QuoteDirect Link to This Post
I did this on my corvette, but I did not plug the hoses, I got a coupler and connected the hoses together under the TB. Not sure I would block the flow of coolant.
Total ratings: 328
Report this Post06-11-2019 06:53 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I drilled and tapped the coolant holes in the intake manifold and put in flush hex head pipe plugs. IIRC they were 1/4 NPT size. The objective was to eliminate any possible leakage and keep the supercharger cooler.
OntarioKev
Report this Post06-12-2019 09:14 PM Click Here to See the Profile for OntarioKevSend a Private Message to OntarioKevEdit/Delete MessageReply w/QuoteDirect Link to This Post
Take a look at the pictures on ZZPs site:
https://zzperformance.com/c...achined-lower-intake
When you get a ported manifold from them they weld the coolant ports. It gives you an idea of what you may want to do.
Lou6t4gto
Report this Post06-18-2019 08:05 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
shows nothing for gen 2 though
DimeMachine
Report this Post06-18-2019 09:14 PM Click Here to See the Profile for DimeMachineSend a Private Message to DimeMachineEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks Dennis. Did it seem to keep the TB and SC cooler with the coolant blocked off - (I imagine - YES) and more importantly, do you believe it yielded more power due to cooler denser charge and perhaps a tad more timing without KR?
Total ratings: 328
Report this Post06-21-2019 07:29 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Haven't done a before and after test but the engine feels smoother and pulls harder. Since I also added a SSIC the test might be a bit flawed but IMO anything to lower intake manifold temperatures is beneficial.
Total ratings: 328
Report this Post06-21-2019 07:32 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Member since May 2000
duplicate post removed
[This message has been edited by Dennis LaGrua (edited 06-23-2019).]
