  Fuel pump and throttle body problems
Fuel pump and throttle body problems by jaredaltizer
Started on: 06-08-2019 11:30 PM
Replies: 4 (189 views)
Last post by: jaredaltizer on 06-12-2019 01:17 PM
jaredaltizer
Report this Post06-08-2019 11:30 PM Click Here to See the Profile for jaredaltizerSend a Private Message to jaredaltizerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hello PFFers.
Recently, I have taken on the task of swapping my stock 2.8 V6 out for a lower-mileage one, because I threw a rod in my original motor. This has been my first and (hopefully) only engine swap. After finally getting the engine and cradle back into the car with most of the vacuum lines and wiring harness hooked up, I have run into a couple problems.
My first problem is what I think is the fuel pump. The new engine will crank and turn over, but usually dies within a second or two. My buddy then told me to try starting the car again while he sprayed brake cleaner onto the throttle body, which seemed to work. He was able to keep it running as long as he sprayed the brake cleaner. I am assuming that this means I have a fuel-related issue. I can hear the fuel pump prime when I turn the key in the ignition, but I assume that it just won't stay pumping. Are there any suggestions on where to start looking for a fix? (Without the obvious answer of "buy a new fuel pump", as it was working with the old engine.)
My second problem is the throttle cable and attaching it to the throttle body. I cannot remember how the throttle cable (and cruise control cable) connect to the throttle body. Would anyone be able to help me out and post some pictures?
Total ratings: 466
Report this Post06-09-2019 12:46 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Don't make guesses... check the fuel pressure!
Total ratings: 328
Report this Post06-10-2019 09:34 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Exactly. You can't solve problems in the blind! Place a gauge on the schrader fitting on the fuel rail and see what it reads. Somewhere in the neighborhood of 38-43 lbs at idle is where it should read. NO pressure = defective fuel pump. Low fuel pressure = bad FP regulator.
randy86
Report this Post06-12-2019 01:14 PM Click Here to See the Profile for randy86Send a Private Message to randy86Edit/Delete MessageReply w/QuoteDirect Link to This Post
No pressure could also be bad injectors, because one or more is stuck open.
jaredaltizer
Report this Post06-12-2019 01:17 PM Click Here to See the Profile for jaredaltizerSend a Private Message to jaredaltizerEdit/Delete MessageReply w/QuoteDirect Link to This Post
I changed out the injectors yesterday, and they were my problem. 4 out of the 6 of the injectors had the caps broken off.
