See my Cave,
Vac Leaksbooster and line sees Manifold vac at idle.
Booster CV "closes" to keep Vac in the booster when you mash to gas or engine is off.
Start car for 1-2 minute.
Shut off and wait a 3-5 minutes minimum. Go for coffee etc.
Then Push brake pedal. should have enough vac reserve to run brakes normally 2 or 3 times becoming harder and harder to push each time. To the point pushed w/ both feet barely moves.
If that works then CV and booster itself isn't your problem. Hoses and hard line to them maybe.
Most vac leaks are somewhere in the engine bay.
Many booster problems are same plus 84-86 w/ booster filters that plugs up there.
