i noticed some coolant sitting around the injector holes 4&6. i can see oil sitting in the intake manifold valley under the supercharger when looking at the injectors 4&6. so i popped the rad cap on the motor and seen a couple drops of oil there. I went and looked in my coolant reservoir and theres tons of oil there. I popped the cap at the rad and only coolant came out due to me not putting the rad cap back on at the engine.
------------------ 86 SE Convertible 3800sc 4t65e HD(2002), Gen V, 3.3 pulley, SD headers
[This message has been edited by Tweeder (edited 05-31-2019).]
Ok. It sounds like oil is getting into your cooling system, right?... I have seen where the cooler inside the radiator tank leaks ever soo slightly. Enough that transmission pressure going to the cooler leaks fluid into the radiator. Is the transmission low on fluid? Is the trans fluid coffee with cream color?? On that note, how’s the color of the oil, coffee/ cream color? Anywhere water and oil are near each other could be a possibility.
-Oil floats on water so the oil almost always wind up in the reservoir since it will be the highest point-
And in your pic, you only removed the upper intake part. I don’t think any coolant goes through the upper, but I do know that coolant goes through the lower intake.. I would remove the lower and check. In my experience the intake gaskets are a high failure point.
[This message has been edited by Crasian (edited 05-31-2019).]
I'll have to check the trans fluid as I dont know. I figured it was the upper as I had coolant and oil on top of the lower intake. Look at the pic and the square where the rotors are, there are small valleys that are at the top and bottom left hand side of that square. That where there was oil, might have been from the valve covers? But that doesnt explain where the coolant sitting around the injector holes came from? I can pull the LIM as I have gaskets for it, just didnt want to go that deep in if infact it's the heads.
Edit:: checked the tranny fluid and alls good there ------------------ 86 SE Convertible 3800sc 4t65e HD(2002), Gen V, 3.3 pulley, SD headers
Get a cooling system tester and pump it up to 18 psi. If the gauge doesn't hold then the cooling system is leaking. As for an oil leak there is no oil going through the intake manifold. What could be happening is a leak at the o rings that allow coolant to flow through the supercharger. A breach there could allow coolant to flow over to the PCV hole and get in the oil. If the manifold gaskets are gone (common BTW on these engines) that could allow coolant in the oil as well or oil in the coolant. On my installs I drill and tap those upper intake O ring holes and plug them to insure no leak there. If you believe that the oil leak is at the head gasket, do a compression test to tell if any cylinder is giving abnormal readings.
I cant test the coolant pressure as the sc is off. What o rings are you talking about, the two yellow ones under the sc? I dont see any sign of leakage there in the pic? The intake manifold gaskets are original so It could be there, I'll have to remove the LIM to check. I have that gasket set on my shelf. I'm hoping it's not the head gasket as I didnt see any white exhaust and my temps were normal, although I know those aren't the only warnings. I noticed my oil isn't on the dipstick so I dont know exactly how much oil is in the coolant overflow. I'll have to drain the oil to see if the coolant has made it in there.
