I am having an issue with the left turn signal not working on my Fiero. If the running lights are off the signal works and blinks just fine, however when the running/headlights are on I can see the left indicator on the dash lit up very dim (without engaging the left signal). With the lights on once I try to engage the left turn signal the dim light on the dash disappears but no left signal/blinking.
The left brake light also does not light up when pressing the brakes. The bulb is not burnt, and was replaced with a new bulb, but still the same issue.
I have replaced the front left turn signal socket thinking it was a ground issue there, but I still the same symptoms. I do not know if it is a coincidence that both issues are happening on the left side.
Any help/insight is greatly appreciated. I am not too sure where the issue might be residing.
[This message has been edited by FieroRob94 (edited 05-18-2019).]
