  Max Horse of Stock Axles
Max Horse of Stock Axles by RussellCupples
Started on: 05-17-2019 08:17 PM
Replies: 9 (280 views)
Last post by: Dennis LaGrua on 05-18-2019 10:38 PM
RussellCupples
Report this Post05-17-2019 08:17 PM Click Here to See the Profile for RussellCupplesSend a Private Message to RussellCupplesEdit/Delete MessageReply w/QuoteDirect Link to This Post
What is the most a stock 4 cyl Fiero axle can handle and is there a hd that will drop right in??
Total ratings: 260
Report this Post05-17-2019 08:58 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
4 cylinder axles are same as 6 cylinder axles. The manual axles are thicker and stronger than the stock auto axles.
OEM fiero manual axles are quite strong and will hold more power than most people will have.
Wheel hop with sticky tires at any power level will break them.
RussellCupples
Report this Post05-17-2019 10:40 PM Click Here to See the Profile for RussellCupplesSend a Private Message to RussellCupplesEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you so much for chiming in . Will the straight shift axles fit in the Auto?? I am assuming not
Total ratings: 207
Report this Post05-18-2019 12:08 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
The driver side manual axle will fit the driver side auto transmission.
The passenger side do not interchange.
RussellCupples
Report this Post05-18-2019 01:02 AM Click Here to See the Profile for RussellCupplesSend a Private Message to RussellCupplesEdit/Delete MessageReply w/QuoteDirect Link to This Post
TY a lot Joe .
Total ratings: 260
Report this Post05-18-2019 08:52 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
The DS Auto axle has a female tripot and the Manual DS axle has a male tripod. The axle shaft lengths might be close to the same length, but I haven't ever tried to swap the Tripot assembly between a fiero auto and manual axle.
Total ratings: 207
Report this Post05-18-2019 11:20 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
The driver side manual axle also has a female tripot.
It can be used on the TH125C, 4T60, 4T60E and 4T65E and 4T65E-HD.
The tripots can not be switched between manual and auto, due internal roller diameters and axle splining differences.
I am striking this post, as I am not able to verify this information at the moment.
The driver side manual axle, as guru stated, has a male tripot.
Sorry for the misinformation.
[This message has been edited by olejoedad (edited 05-20-2019).]
RussellCupples
Report this Post05-18-2019 11:30 AM Click Here to See the Profile for RussellCupplesSend a Private Message to RussellCupplesEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks so much again Ole Joe
RussellCupples
Report this Post05-18-2019 07:41 PM Click Here to See the Profile for RussellCupplesSend a Private Message to RussellCupplesEdit/Delete MessageReply w/QuoteDirect Link to This Post
RussellCupples
Member since Mar 2019
No problem sir
Total ratings: 328
Report this Post05-18-2019 10:38 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Forum member Darkhorizon (Scott) ran a 9.87 sec @147 mph 1/4 mile time in his 86 GT with a heavily turbocharged and nitrous fed 3800 engine with a 4T65eHD transmission. AFAIK, he ran stock GM axles . To run that time his engine must be making 600 HP .
