I am pretty new to fieros and my mechanical skills are below average (may have bought the wrong cars, ha). Anyway, I thought I would reach out to the experienced people on the board to help me narrow down my problem before I take it to someone.
I have an 88GT with the 5-speed. It has 23K miles. Two days ago, I took it out and it was running great. I suddenly heard a "groaning" noise which seemed to be coming from my gear box; definitely not the engine; at first I thought the sound was my breaks rubbing but eliminated that as an option. We headed home and noticed this only happened as I was slowing down. It didn't matter what gear (or no gear) I was in or if I had the clutch in or not. The car again made a loud sound like something was rubbing and the engine died as I coasted to a stop. The engine started right back up and accelerated through the gears with no issues, but I continued to hear a "groaning" from the middle of the car as I slowed to a stop and it died two more times before I got home (not good). Am I right to assume it is a clutch problem? My gearbox? Where should I begin?
Todd
------------------ Todd 1988 GT
[This message has been edited by Mcgheejt (edited 05-17-2019).]
This does sound like a mechanical issue so it should be easy to track down (hopefully). Based on the sound you're hearing, I'd start by measuring the movement of the clutch slave cylinder. You should see it move about 1-1/8". If it's less then it is a problem on the hydraulic side, otherwise it could be a pressure plate or (less likely) a transaxle issue.
If you get the same result with the car out of gear I don't think the clutch would come into play. You say the sound seems to emanate from the middle of the car. It could be a bad fuel pump or maybe a fuel filter that needs to be changed. Certainly with the low mileage you quote, the car has set for long periods of time. That can lead to rust and sediment buildup inside the tank.
An AC compressor can also drag the engine down and it has a wide repertoire of noises.
I'm guessing bad fuel pump, or clogged fuel filter.
If the clutch were dragging, you'd feel the car trying to creep forward at a stop, like an automatic transmission. Plus it would be difficult to get into 1st gear, from a stop. It would also cook the clutch, and you'd smell that. There's really no way the clutch can stall the engine while the car is moving.
Also, if the A/C compressor locks up, it'll smoke the belt. Ask me how I know this.
[This message has been edited by Blacktree (edited 05-17-2019).]
Maybe not related but here is what is happening to me...
When I slow down and most often just before I am stopped my 87GT manual has been shutting of rather quietly for about a week now. Yes bragging, but I am not much to miss shifts but have ground the gears a handful of times this past week embarrassingly. Really good newbie grinds.
Newish Rodney Dickman parts throughout.
No leaks up until I hit the inside fire well carpeting just above the clutch master cylinder and banjo assembly. I started at the master and it appeared full. I went back to the slave and nothing. Dry. I followed the line to the foot well and was finally thankful to get somewhere.
I have not determined the exact issue as of writing, but figured this would perhaps help you in the right direction. Someone here will nail it.
Mcgheejt, Sitting still with the car running in neutral try pushing the clutch pedal in and out. If there is a difference in sound/pitch with pedal in or out, it may be a bad throw out bearing. I agree with having that low mileage, the car sat a lot maybe for an extended period, and things dried out.
PS: How bout a bad tire, low air pressure, or rubbing on something. You may have two unrelated problems with the noise, and the stalling...
[This message has been edited by FX (edited 05-17-2019).]
Originally posted by fierofool:You say the sound seems to emanate from the middle of the car. It could be a bad fuel pump or maybe a fuel filter that needs to be changed. Certainly with the low mileage you quote, the car has set for long periods of time. That can lead to rust and sediment buildup inside the tank.
I'd hate to ask the obvious, but since you mentioned it happens when slowing down: Do you have gas?
The fuel tank is long and narrow, with the pump at the back. If you're driving on a near literally empty tank, then breaking can cause the remaining gas to slosh away from the pickup. The pump gets *very* loud when it runs dry.
Like Blacktree, ask me how I know
Hmmm, well, the gas gauge says 1/4 tank, but then again, my other fiero's gauge is routinely wrong. Maybe it doesn't have enough gas to keep the pressure. I didn't know the pump got load if it was running dry, so I guess I will do the obvious and go fill her up before panicking.
When you fill it up, lock the nozzle on the lowest flow setting. When it cuts off don't continue trying to top it off. If you do this regularly you will almost always have the same amount of gas at a fillup. It also reduces the possibility of saturating your charcoal evap canister.
Once filled up, reset the trip odometer and drive the car about 150 miles. Fill it again in the same manner and determine your mpg. If you then reset your trip odometer every time and fill up every time you need fuel, you won't have to worry about an inaccurate gauge. You can run about 7 gallons out of a full 87 tank and still keep enough fuel in the tank to keep the fuel pump cool so it doesn't bun out.
When the fuel level is low and sloshes back and forth, the pump will get air instead of fuel...and make a lot of noise. If you drive conservatively, you can usually make it to the next gas station with no trouble.....this is a handy safety feature that I have utilized more than once..
The WISDOM on this board is immeasurable. The Noobs of the world thank you.
If you put the pedal to the metal in each gear you can cause all the gasoline to run to the back at the fuel pump. When you're up to speed push in the clutch and coast for a while. Then do it all over again.
