If the parking brakes works then Do Not take the piston apart for any reason. might be good to rinse inside where springs etc work in w/ new fluid to remove old old fluid and crap in there. Do not put anything in the pad side vent hole.
Rear pistons was never design to rebuild and not even GM Dealers have any data for doing so in FSM and other GM doc's for Fiero and several other car lines.
If you follow BS that claims you can rebuild the pistons on YT PFF etc then you better have good insurance and pray.
And Do Not Hone the bores. Honing can create more problems for aluminum caliper bodies. Bores Do Not touch the Pistons in disk brakes so just remove crap stuck on the bottom of bores.
