Has anyone done 275 tires on the back of a non-88 suspension? I have 255/45/17s with coilovers in the back .... Wheels have +35 offset and with coilovers the tires are almost kissing the coilovers but has almost no poke. I know handful of 88s are running 275s and at this point every little bit will help
An 84-87 car can fit 18x9.5 C5 Corvette rear wheels with 1" thick adapters and run 285/30-18 tires.
Of course those wheels will also fit the Corvette 275/40-18 size, but those are significantly taller. 275/35-18 would probably work pretty well, although those have been known to rub the wheel house liner on '88's when used on a race track that turns.
An 84-87 car can fit 18x9.5 C5 Corvette rear wheels with 1" adapters and run 285/30-18 tires.
So my question would be what are the bearing loads incurred by running that offset and wheel tire width? Also that means the front wheels and tires would be wider as well? What would you run up front? looks like major change to the scrub radius?
Most of these extreme wheel fitments under the stock body are gaining width on the backside of the wheel/tire which better centers the wheel to the bearing and reduces scrub radius. I run 235/40/17 and 285/30/18 combo on my 88.
That seems to be easy on the 88s, and they seem to be a lot more forgiving offset wise.... I'd be more than happy running 215/275 combo rather than the 225/255 I have right now
The 84-87 can go wider with a 17" wheel than the 88 can. The 88's have to go to 18's to clear the strut mounting flange for additional width, so there are trade offs for both.
For my car, the first point of interference is the trailing link that the 84-87 doesn't have. The 84-87 struts are slightly more vertical, but you could mount your coilovers higher on the strut (like on the oem spring perch weld bead) to maximize wheel/tire clearance.
You can also move the top of the struts further inboard. Mine are 1" further inboard than stock 88 or close to 2" further inboard from the 84-87.
Another option is to do the Fog mod... He put 325s under his 84/87. He cut out the bolt pattern area of the strut tower and flipped it around to move it inboard 2 1/4". He also cut 1 7/8" out of the lower a-arm and pulled everything inboard to allow more wheel/tire on the outside. He did flare the top of the fenders some... but they were 325s!.
With my coilovers on my 87 I am running a 255/35 18 and have a lot of room. The rim is a +35 offset as well. I thought about going to a 275 at one point but ultimately went with the 255. It is still a 10" wide tire and fills the back nice. The tire tucks in just fine with not scrubbing.
Good advice, I don't need a whole lot... I prefer 17s anyway.... Id be happy with 17x9 275 tires, shouldn't need too much more to safely tug along as we inch up the power scale Edit: what did you exactly do to make the struts more inboard, do you have a write up on this?
[This message has been edited by Blowerwhine (edited 05-15-2019).]
Bearing load has more to do with how much of the tire's grip you utilize when you drive. I also didn't mention the fronts... just the rears.
A Fiero with 45/55 weight distribution should have front wheels and tires that are ~82% (45/55=0.82) as wide as the rear wheels tires. Thus a 7.5 is about the right front wheel to run with a 9.5 rear wheel, and a 225 about the right front tire with a 275 rear.
[This message has been edited by Will (edited 05-15-2019).]
Originally posted by Will: A Fiero with 45/55 weight distribution should have front wheels and tires that are ~82% (45/55=0.82) as wide as the rear wheels tires. Thus a 7.5 is about the right front wheel to run with a 9.5 rear wheel, and a 225 about the right front tire with a 275 rear.
With a 3800TC/4T65 I'm sure the weight balance is closer to 40/60... The front end feels very light!
