  Can a 4.9 have A/C?
Can a 4.9 have A/C? by Darren's 87 coupe
Started on: 05-05-2019 01:47 PM
Replies: 4 (521 views)
Last post by: Darren's 87 coupe on 05-06-2019 02:26 PM
Darren's 87 coupe
Report this Post05-05-2019 01:47 PM Click Here to See the Profile for Darren's 87 coupeSend a Private Message to Darren's 87 coupeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Mine is gone now but when I was building mine, I never got a clear answer if anybody had gotten the 4.9 system to work.
Total ratings: 207
Report this Post05-05-2019 02:32 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, it's not a problem at all.
Total ratings: 328
Report this Post05-05-2019 08:42 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
No reason that the 4.9L can't be connected to the Fiero A/C system. You will just need a new hose. All the A/C compressor hose connectors are available online to mate the compressor to the manifold on the firewall. On the firewall side you just use the old Fiero connector with new O rings. My setup will use the Cadillac A/C compressor but as such a high pressure switch must be added on the high side line. Without the switch the system can build excessive pressures as in the Fiero Factory install, many of which failed.
Mickey_Moose
Total ratings: 145
Report this Post05-06-2019 12:39 PM Click Here to See the Profile for Mickey_MooseSend a Private Message to Mickey_MooseEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you want to use the Fiero's compressor, you have to change the clutch assembly out so that it can run the serpentine 4.9l belt.
I need to put the pictures back in my thread: https://www.fiero.nl/forum/Forum2/HTML/098096.html
Darren's 87 coupe
Report this Post05-06-2019 02:26 PM Click Here to See the Profile for Darren's 87 coupeSend a Private Message to Darren's 87 coupeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the help guys!
