  Need help with window adjustment
Need help with window adjustment by Habanera Hal
Started on: 04-18-2019 03:56 PM
Replies: 2 (133 views)
Last post by: fierosound on 04-19-2019 09:36 AM
Habanera Hal
Report this Post04-18-2019 03:56 PM Click Here to See the Profile for Habanera HalSend a Private Message to Habanera HalEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi all.
I'm attempting to install power windows into my 88 Formula. I went with an after-market style winder that attaches to and turns the original crank stub. The installation on the driver's side works fine, but I'm having difficulty with the passenger side. The window powers down fine, but hangs up when raising about half-way up. If I remove the power winder and crank the window by hand, I can feel a slight binding (?) about halfway up. That's not a problem with manual windows, but the power motors don't seem to have enough torque to power past that. If I rock the switch up and down, I can get it almost all the way up.
How do I adjust the window so it is "looser" and has less resistance when being raised?
donuteater306
Report this Post04-18-2019 09:47 PM Click Here to See the Profile for donuteater306Send a Private Message to donuteater306Edit/Delete MessageReply w/QuoteDirect Link to This Post
More than likely you need to clean/grease the tracks. Passenger side gets used less often so I doubt it's worn.
fierosound
Total ratings: 286
Report this Post04-19-2019 09:36 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Window adjustments
https://www.fierostore.com/.../Default.aspx?Id=365
