| quote | Originally posted by Lou6t4gto:
Brakes, what Year S10/blazer BOOSTER is needed for the swap ? I know 1996 fits, but what other years? Thanks |
Why use other year boosters when the brake Booster for 96 Chevrolet S-10 2 wheel dr. fits. Below are the part numbers. They might fit other vehicles.
Cardone 54-71061 Summit 760125
*Tough Stuff 2232N Kit *only one that can be directly used with Rodney Dickmans adapter end.
Cut off Fiero Rod 4.312” Long Thread 3/8-16 threads
Cut S-10 booster rod at banjo hole. Thread S-10 Cylinder rod 1.5” Long.
Use threaded longnut to attach rods together.
Extend actuator Rod to 9 3/8” Body to Center hole measurement use. Use nuts to tighten in place using Locktite
Use Fiero bracket
I used the Tuff Stuff booster with Rodney Dickmans adapter end. You can also buy a completed unit from Sardonix on this forum. These choices are nearly plug and play only because a small amount of space must be opened up for the larger booster to fit. One of the best effective inexpensive mods that I've ever made.
