  1985 2.5 Does not return to idle when clutch is pushed in and accelerator released
1985 2.5 Does not return to idle when clutch is pushed in and accelerator released by Bruce8524m
Started on: 04-15-2019 08:11 PM
Replies: 7 (119 views)
Last post by: Gall757 on 04-20-2019 09:27 PM
Bruce8524m
Report this Post04-15-2019 08:11 PM Click Here to See the Profile for Bruce8524mSend a Private Message to Bruce8524mEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have an 85 2.5 Fiero. It idles smoothly but when driving the RPMs usually don't return to idle when the clutch in pushed in. If I kick the accellerator it will drop back down to normal idle. It seems like the cable or linkage may be sticking. Possibly the return spring being too weak. Before I start messing with the mechanical linkage, I was wondering if there could be an electrical issue here. I've replaced the throttle position sensor and checked for vacuum leaks. The problem seems to get worse when the engine is at operating temp. Any ideas would be appreciated.
JMTUT
Report this Post04-15-2019 11:44 PM Click Here to See the Profile for JMTUTSend a Private Message to JMTUTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Following because I have the exact same issue 85 2.5. Mine has two springs on the throttle so I assume the PO tried to increase the tension on the cable. I've even let out on the clutch without pressing the accelerator and it still does the same thing. Idles about 900 but goes up to 1100-1200 unless I blip the throttle.
Total ratings: 458
Report this Post04-16-2019 12:31 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Neither one of you has mentioned checking the operation of the IAC.... and/or whether you've thoroughly cleaned out the seat and air passage area of the IAC.
JMTUT
Report this Post04-16-2019 11:37 AM Click Here to See the Profile for JMTUTSend a Private Message to JMTUTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've completely rebuilt my throttle body, cleaned the IAC and EGR passages and replaced the IAC with a new one. I suspect I may have a slight leak at the intake manifold gasket but haven't found the time/energy to replace the gasket.
Bruce8524m
Report this Post04-18-2019 12:22 PM Click Here to See the Profile for Bruce8524mSend a Private Message to Bruce8524mEdit/Delete MessageReply w/QuoteDirect Link to This Post
The throttle body was cleaned, the IAC and TPS was replaced, as was all vac hoses and the PCV valve. Can't detect any vac leaks. The idle is steady (though a bit high at around 900 rmp). Overall, runs well at idle, you just need to blip the pedal to return to normal idle.
Total ratings: 568
Report this Post04-18-2019 04:37 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
ECM may keep Idle high when you do this.
ECM goes by engine temp etc to set idle at any time.
For stick cars often idle a bit high to prevent stalling then back down a bit later.
Can be Vacuum leaks too. See my Cave, Vac Leaks
Bruce8524m
Report this Post04-20-2019 08:03 PM Click Here to See the Profile for Bruce8524mSend a Private Message to Bruce8524mEdit/Delete MessageReply w/QuoteDirect Link to This Post
Update. Ogre, thanks for the link on vac leaks. I checked the vapor recovery canister and the large line (the one below the control line) would not hold a vac. I replaced the canister with a working one from an 86 GT at a u-pick yard and it seems to have resolved the issue. It still idles a bit high (1000 rpm at operating temp), so there may still be another vac leak, but at least now it is drivable. Thanks for the help.
Report this Post04-20-2019 09:27 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
1000 rpm on the Fiero Tach is within the usual margin of error.
