  Help buying/finding an A/C evaporator
Help buying/finding an A/C evaporator by Threedog
Started on: 04-15-2019 12:40 PM
Replies: 5 (383 views)
Last post by: Threedog on 04-18-2019 10:07 AM
Threedog
Total ratings: 61
Report this Post04-15-2019 12:40 PM Click Here to See the Profile for ThreedogSend a Private Message to ThreedogEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have a 3800(L67) with all the necessary parts for working A/C, but I have a leak(I can get the system to work for two-three weeks, but it slowly loses pressure and stops unless refilled).
I replaced the compressor, accumulator, expansion valve, orifice tube, and seals in the engine bay, yet it still leaks.
I ran a UV light over the lines by the gas tank and have not found any leaks, which makes me think it has to be the evaporator. Problem is, I can't find one for sale. Anywhere. Amazon and O Reilly do not have one listed. The only ones listed on ebay push $300+, is that how much I should expect to pay? Is there a good way to know if it is leaking or not besides running a UV light over it?
vette7584
Report this Post04-16-2019 08:53 AM Click Here to See the Profile for vette7584Send a Private Message to vette7584Edit/Delete MessageReply w/QuoteDirect Link to This Post
i have the same issue and i have already replaced my evaporator core. following this post
ltlfrari
Total ratings: 127
Report this Post04-16-2019 08:53 AM Click Here to See the Profile for ltlfrariClick Here to visit ltlfrari's HomePageSend a Private Message to ltlfrariEdit/Delete MessageReply w/QuoteDirect Link to This Post
I got mine from here http://fierofiberglass.com/index.html several years ago (misc section). Looks like the fiberglass part of the business is/was up for sale so I have no idea if he still sells them or or not or if if he can point you at his supplier. Maybe worth sending an email
Found this one from old air https://www.oldairproducts....gfid=p117549-c118557 but at $320 it's up thee price wise.
Don't know anything else about it though.
Then I found these https://www.restomodair.com...otive-ac-condensers/
Just the condenser part. Don't know which one if any will fit and you'd need to do some work to transfer parts from old unit to this one but they are a lot cheaper! This or some similar custom unit may be the way to go as parts like this get scarce
Another https://obsoleteair.com/pro...-ac-air-conditioning
Looks like $300 is in the ballpark these days. Who said Fieros would never be worth anything!
Dave
www.ltlfrari.com
[This message has been edited by ltlfrari (edited 04-16-2019).]
Report this Post04-16-2019 10:30 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you can size one properly you just need a generic evaporator about the same size and just make up new hoses for the connections or aluminum solder new ones on. Some work but more cost effective than $300. That's pretty steep.
Report this Post04-16-2019 10:54 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have several of them.
Threedog
Total ratings: 61
Report this Post04-18-2019 10:07 AM Click Here to See the Profile for ThreedogSend a Private Message to ThreedogEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well..how much you want for one? Used or new?
