Okay, so a new board changed nothing. Next idea?
Checking again, this is what it is doing:
1. Low, high, and mist work as designed
2. At the fastest point of the delay wiper range, it is slightly slower than Low as you would expect.
3. As you attempt to slow down more from there, they get only slightly slower, with no discernible difference down to what should be the slowest wiper rate within the intermittent range.
Bottom line, there is no speed difference from what should be the slowest point up to about the 80% mark within the intermittent range. This occurred with both the OEM board and the new Dorman board.
[This message has been edited by USMUCL (edited 04-17-2019).]
