...I just went out there. As I thought, everything is steel. The pedal, the riveted on U bracket, and the switch mount. Now I'm wondering if the pedal return spring could just be getting weaker, and not allowing the pedal to come back far enough to hit the switch. I'll have to take the switch out to check that, and see if the pedal will come up even farther with the switch not there to stop it. I've read that some guys don't put the return spring back in after they've had the pedal out... Clutch works fine. Is that spring a critical necessity, and will it getting weaker cause a problem?
Bob
[This message has been edited by FX (edited 04-12-2019).]
