  firing order ,plug location 3800SC
firing order ,plug location 3800SC by Lou6t4gto
Started on: 04-12-2019 01:07 AM
Replies: 9 (234 views)
Last post by: MulletproofMonk on 04-17-2019 09:37 AM
Lou6t4gto
Report this Post04-12-2019 01:07 AM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
1999 3800 sc swap. the cylinder location is 1 3 5 "From the Front of the engine" Under the rear window, 2 4 6 from the Front of the engine , closer to the trunk. What is the
"right plug wire" Location "on the coil pack"??? Starting from the end( "Without the Wire Harness,) is it 6 3 2 5 4 1 ???? every time I look it up online, there are 27 different versions! thanks
Total ratings: 205
Report this Post04-12-2019 07:13 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Look carefully at the ICM, the order is cast onto the metal.
Threedog
Total ratings: 62
Report this Post04-12-2019 11:48 AM Click Here to See the Profile for ThreedogSend a Private Message to ThreedogEdit/Delete MessageReply w/QuoteDirect Link to This Post
Total ratings: 205
Report this Post04-12-2019 12:10 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
S/C cars are VIN 1, firing order is the same.
Lou6t4gto
Report this Post04-12-2019 01:49 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
WHERE on the ICM, on the Bottom or under the coils? Thanks, never knew that
Total ratings: 205
Report this Post04-12-2019 01:57 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Cast onto the rim, IIRC, under the coils.
darbysan
Report this Post04-13-2019 11:02 AM Click Here to See the Profile for darbysanSend a Private Message to darbysanEdit/Delete MessageReply w/QuoteDirect Link to This Post
If it makes routing the wires any cleaner, the two wires on any single coil can be interchanged, since both fire at the same time. This may be why you have found confusing info in postings.
'87 GT , '00 3800 Series II SC, 4t65e, Vue Power Steering. (SOLD)
Lou6t4gto
Report this Post04-13-2019 01:07 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
need clarification. WHY would 2 cylinders fire at the same time ?
Total ratings: 205
Report this Post04-13-2019 01:46 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
It's called loost spark ignition, the power cylinder burns fuel, the lost spark cylinder fires the plug to help emissions. The lost spark cylinder is empty, top of the exhaust stroke, IIRC.
MulletproofMonk
Total ratings: 78
Report this Post04-17-2019 09:37 AM Click Here to See the Profile for MulletproofMonkClick Here to visit MulletproofMonk's HomePageSend a Private Message to MulletproofMonkEdit/Delete MessageReply w/QuoteDirect Link to This Post
//www.fiero.nl/forum/A...130314-2-118039.html
//www.fiero.nl/forum/A...130314-2-118677.html
[This message has been edited by MulletproofMonk (edited 04-17-2019).]
