  trans Swap
trans Swap by Lou6t4gto
Started on: 04-06-2019 05:43 PM
Replies: 1 (141 views)
Last post by: olejoedad on 04-06-2019 06:34 PM
Lou6t4gto
Report this Post04-06-2019 05:43 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
1985 is a 4t60 a Direct replacement for a 125 ? bolt up, axles, plug for lockup ??? if I have to rebuild one, I'd rather have overdrive. thanks
Total ratings: 205
Report this Post04-06-2019 06:34 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bolts to block, can use factory GM brackets from 4T60, but need to move mounts inboard on cradle, passenger axle the same, different axle on driver side. Must modify shift cable bracket and arm, use adjustable shift cable.
Use Fiero kickdown cable.
Tap vacuum port in upper plenum for transmission vacuum solenoid.
[This message has been edited by olejoedad (edited 04-06-2019).]
