  Dashlight Indicator List!?
Dashlight Indicator List!? by fieroeffect
Started on: 03-30-2019 05:20 AM
Replies: 6 (213 views)
Last post by: Gall757 on 03-31-2019 09:19 AM
fieroeffect
Report this Post03-30-2019 05:20 AM Click Here to See the Profile for fieroeffectSend a Private Message to fieroeffectEdit/Delete MessageReply w/QuoteDirect Link to This Post
Is there a layout or map which lists exactly which warning indicators are in the 10 squares in the dash cluster? ‘85 SE 2M6 THANKS!
Total ratings: 154
Report this Post03-30-2019 07:22 AM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
From the 85 Owner's Manual. Top to bottom.
Left side: Deck Ajar, Left Turn Indicator, Door Ajar, High Beam Indicator, Brake
Right side: (Up) Shift, Right Turn Indicator, Battery, Seat Belt, Check Engine
The Shift light function may or may not be activated in the ECM.
[This message has been edited by fierofool (edited 03-30-2019).]
Total ratings: 568
Report this Post03-30-2019 01:53 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
See //www.fiero.nl/forum/Forum2/HTML/138175.html
All Instrument panel bulbs are there.
fieroeffect
Report this Post03-30-2019 06:15 PM Click Here to See the Profile for fieroeffectSend a Private Message to fieroeffectEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks.
Going over a hard bump once in a while, the dash indicator light for Coolant Temp lights up less than half a second. Actual engine temp gauge, coolant tank, rad and fan working as expected. Loose connection? Thoughts?
Total ratings: 154
Report this Post03-30-2019 07:24 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Check the Temp Gauge Temp Light sender at the drivers end of the trunkside head, next to the #5 exhaust port. It may be your problem. It will have a green and a green with white tracer wire coming from it. If you need a new harness end, Rodney Dickman sells them.
fieroeffect
Report this Post03-31-2019 04:26 AM Click Here to See the Profile for fieroeffectSend a Private Message to fieroeffectEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hey thanks!
Is there a diagram you can point out where to check by any chance?
Thanks
Report this Post03-31-2019 09:19 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
The connector is probably coming apart......
[This message has been edited by Gall757 (edited 03-31-2019).]
