try to start and no fuel when you look down the TBI likely Ignition or ECM is "dead."
ECM won't turn on the injector w/o seeing Igntion signal.
ECM can "die" from heat and cracked solder joints causing same
Fuel pump can have problems too.
all w/o setting codes.
Try See my Cave,
ECM Heat or just remove the console. Even try tapping ECM w/ fingers may help.
If that helps get rebuilt ECM locally
and move the prom inside to the new unit.
