  rodney dickman clutch line repair kit
rodney dickman clutch line repair kit by yamaha94
Started on: 03-16-2019 03:12 PM
Replies: 2 (383 views)
Last post by: Gall757 on 03-20-2019 07:41 AM
yamaha94
Report this Post03-16-2019 03:12 PM Click Here to See the Profile for yamaha94Send a Private Message to yamaha94Edit/Delete MessageReply w/QuoteDirect Link to This Post
hi everyone,
i am in the midst of installing the rodney dickman clutch line repair kit to my new slave unit.... has anyone installed this before? if so, where did you make the cut to the clutch line and installed the compression fitting? there seems to be a lot of line it looks like i have to make a 90 degree bend and there is a straight section where the fitting may be installed.
thanks
marcus
yamaha94
Report this Post03-19-2019 10:07 PM Click Here to See the Profile for yamaha94Send a Private Message to yamaha94Edit/Delete MessageReply w/QuoteDirect Link to This Post
Figured it out.. easy install. no bends needed. after the OEM clutch line goes on a 90 degree bend there is a small straight section. i cut that in half and spliced in the replacement clutch line. works great.
thanks
Report this Post03-20-2019 07:41 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by yamaha94:
thanks
you're welcome! from the PFF self-help staff.
