To the OP I say pull the cleaner looking head, check it for leakage and straightness. If within spec install it on the engine with a new head gasket. Then do a cylinder leakdown test or even a compression test. That will tell you the quality of the piston ring seal but nothing about the rod bearings. Checking those would require pulling the oil pan and checking every rod for looseness.
