| quote | Originally posted by kjelle69: Ok, but does a faulty tach filter really make the engine stop and die? |
That and worse can kill ICM, HEI Coil, etc because when the tack parts "die" can causing them to overheat and kill them too.
Ignition doesn't care if tach and filter are not connected but People bypass the filter so OE tach still works can have same problem w/ iffy tach or wiring to the tach. Most Aftermarket Tach can have same problems too.
So just remove the filter and check again then leave filter off trying to fix what else maybe wrong because tach parts may still be bad.
When you fix whatever then try using tach again.
