I'm currently swapping a 3500 VVT LZ4 into my 88 Fiero. I got a great deal on a fully rebuilt 4T45 transmission from a Pontiac G6, so that is the transmission I will be using with it. However, all the custom swap brackets out there are for the 4T
65E.
Since my coupe is an 88 and originally came with a Duke, the path of least resistance would be to use the "shelf" on the cradle that used to have the single transmission mount setup that Dukes had that year. However, I hated that setup, since the powertrain would annoyingly rock back and forth in the engine compartment too much. So I converted my TH125 to the dual mount setup of the V6 models, and it completely fixed that problem. I don't want to recreate that problem with my swap, so I want to avoid using the single transmission mount setup of the 88 Duke.
So I had an idea for a dual mount setup that I wanted to share with all of you here to have your input.
People who swap a non-electronic 4T60 into a Fiero usually try to find transmission brackets from GM cars that offered both the TH125
and the 4T60, to have brackets that will work with the stock Fiero TH125 mounts.
Using the same logic, I came up with a theory that I'd like to test with all the GM experts here. The Chevy Cavalier and Pontiac Sunfire offered both the 3T40 (a renamed TH125)
and the 4T40E, which was later revised and became the 4T45E. Could this mean that Cavalier/Sunfire 4T40E transmission brackets will bolt right up to my 4T45E
and the stock Fiero transmission mounts?
Silver 88 coupe, Duke with TH125C (for now)
White 88 GT, 3800 L67 with 4T65E-HD (sold)
2004 Chrysler Concorde Limited (winter car)
