You often have to loose the big column nuts/bolts mounting to dash frame to get clearance for this at minimum.
Do Not loosen screw holding only Ignition switch!If the D switch is fried then likely need new plug too. Try
www.dormanproducts.com to find one as a pig tail.
Solder it because most others won't handle amps used by HL bulbs.
