Not quite...
V6 EGR is controlled by solenoid that's controlled by ECM.
Do what said above. T the line to EGR and watch vac gauge while you drive. Don't need to watch exact #, just when shows vac at various time, most over 35 mph or more but ECM can demand EGR On at any time. Really need ECM scanner have have help to watch both to match. IOW Scan say EGR On then Gauge should have vac too.
Emissions failures like High NOx can be several things... In no order...
Iffy EGR.
Iffy Cat.
Iffy Ignition Timing or other problems w/ HEI.
Iffy O
2 sensor.
Exhaust leaks can let ail In the system cause iffy O
2 data and/or fake out the Cat.
Burning oil or coolant can make Cat and O
2 problem and poison both that will kill them often w/o Codes setting before O
2 completely die. Poison/Dead cat can be High NOx, fail blocking exhaust, Overheat that can cause a fire, etc.
