  Right turn signal stuck on
Right turn signal stuck on by shemdogg
Started on: 02-05-2019 05:13 PM
Replies: 5 (241 views)
Last post by: shemdogg on 02-08-2019 06:36 PM
shemdogg
Report this Post02-05-2019 05:13 PM Click Here to See the Profile for shemdoggSend a Private Message to shemdoggEdit/Delete MessageReply w/QuoteDirect Link to This Post
Worked fine before i pulled the dash, left side works fine. The blue wire has constant power. Left side blinks fine but indicator is dim
whutdafukduidu? lol
shem
Report this Post02-06-2019 10:27 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
After following your build thread for a while it's hard to imagine what is stock and what is not on your car, but you have lost a ground somewhere....do you still have side marker lights?
original wiring for the front end.
[This message has been edited by Gall757 (edited 02-06-2019).]
mmeyer86gt/gtp
Total ratings: 73
Report this Post02-06-2019 10:43 AM Click Here to See the Profile for mmeyer86gt/gtpSend a Private Message to mmeyer86gt/gtpEdit/Delete MessageReply w/QuoteDirect Link to This Post
either lost a ground or a bulb is out.
shemdogg
Report this Post02-06-2019 05:06 PM Click Here to See the Profile for shemdoggSend a Private Message to shemdoggEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the replies fellas. The rear lights are the only thing hooked up, the front marker lights are not installed on either side. The left works fine but no right side blinking even if I hook up a front marker light. Ill keep playing w it.
shem
Total ratings: 568
Report this Post02-06-2019 07:26 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
You can't just look at the light.
Need to pull all sockets out and look at the bulbs when on.
Iffy sockets or ground(s) can make the bulbs to light but not the right way and thermal flasher won't have enough load etc.
See my Cave, Sneak Path
shemdogg
Report this Post02-08-2019 06:36 PM Click Here to See the Profile for shemdoggSend a Private Message to shemdoggEdit/Delete MessageReply w/QuoteDirect Link to This Post
Busted bus bars behind binnacle! Got em working. Rears n indicators flash getting 12.something, but fronts only get 5.7v. Flashers getting 12.7 on/off. Wirings all butchered, probably just going to run new wires.
shem
