  T-top map light with sub control questions..
T-top map light with sub control questions.. by Crasian
Started on: 02-05-2019 03:36 PM
Replies: 3 (162 views)
Last post by: Crasian on 02-05-2019 09:09 PM
Crasian
Report this Post02-05-2019 03:36 PM Click Here to See the Profile for CrasianSend a Private Message to CrasianEdit/Delete MessageReply w/QuoteDirect Link to This Post
Got a question. My ‘88 t-top didn’t come with the performance sound option. I’m not sure if it was available with that option.. my map light “cover” has a hole where the “slider” would be but it looks like it was made to only work with an earlier set up with the three buttos to turn on a light. Is the sub control put somewhere else? Was the map light cover modified to work with the sub system? I can’t find anything about it at all. Thanks for any input.
*I am asking because I want to install the performance sound system and don’t know how the factory did it.
-Crasian
mrfiero
Total ratings: 149
Report this Post02-05-2019 04:57 PM Click Here to See the Profile for mrfieroSend a Private Message to mrfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Many T-Top GT's came with the performance sound option. You will need to cut the corners off of the maplight with the slider controls so the trim cover will fit. You will then need to carefully remove the bezel that says "Performance Sound" from the original maplight housing. Now screw the T-top trim cover to the maplight housing and glue that "Performance Sound" bezel to the trim cover. You are done!
mrfiero
Total ratings: 149
Report this Post02-05-2019 05:08 PM Click Here to See the Profile for mrfieroSend a Private Message to mrfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
mrfiero
Member since Mar 99
Double post!
[This message has been edited by mrfiero (edited 02-05-2019).]
Crasian
Report this Post02-05-2019 09:09 PM Click Here to See the Profile for CrasianSend a Private Message to CrasianEdit/Delete MessageReply w/QuoteDirect Link to This Post
So that is how it’s done. Thanks for the info!! I try to keep the interior looking as stock and original as possible, totally ‘80’s
