here is a quick write up on how to make your own brackets and what you need.
1. 10-24 3/4 inch screw qty:8
2. 10-24 washer qty:8
3. 2" 1/4 screw qty:8
4. 1/4" lock washer qty:8
5. 1/4" washer qty:24
6. 2" springs qty: 8
7. 1/4" jack crush washers qty:8
8. 18 gauge metal 4 1/8" x 5 1/4' bent as follows 1" /90degree/ 1 3/8" / 90degree/ 2 1/4 left
9. stepper drill bit
10. drill bit for initial hole
1. mount the brackets to the back of the headlight
2. place the headlight with bracket onto the head light carrier
3. use clamps to hold the headlight in place
4. drill 4 holes for the outside screws
5. expand the bolt holes on the headlight carrier to 1/4 using the stepper big
6. expand the holes for rhe out side screws to 1/4
7. install jack plate screw crush bolts
8. install the hardware as shown
