The 85 Fiero V6 ECM is different from the 86-88 units. The 85's are are not interchangeable with the 86-88 ECMs and vice versa . ECM's have manual and auto prom chip versions. They are similar programs with exception of the shift light control (stick) and for the TCC engagement (auto).
To my knowledge both the 85 and 86-up ECMs put out the same injector signal. If you upsize injectors then the base pulse width constant and the fuel tables must be altered for proper performance. Its not a plug and play situation.
