  fiero store sending unit, which wire is positive?
fiero store sending unit, which wire is positive? by vette7584
Started on: 02-01-2019 07:20 PM
Replies: 5 (337 views)
Last post by: fierosound on 02-02-2019 01:02 PM
vette7584
Report this Post02-01-2019 07:20 PM Click Here to See the Profile for vette7584Send a Private Message to vette7584Edit/Delete MessageReply w/QuoteDirect Link to This Post
just purchased a fiero store fuel sending unit, it looks great. my question is this, i am using a fuel pump that does not match the plug on sending unit, my pump is marked on top, + and -, but which wire on the sending unit is positive and which is negative? one is grey, and one is black, the obvious would be that black is negative, but i just want to know if anyone else has done this? thanks!
tazome
Report this Post02-01-2019 08:08 PM Click Here to See the Profile for tazomeSend a Private Message to tazomeEdit/Delete MessageReply w/QuoteDirect Link to This Post
i just did the same thing back n july , but i used an AC delco factory pump an i just pluged in , what kind of pump did you get? i know the fiero stores sending unit also came with adapters for non ac pump
vette7584
Report this Post02-01-2019 08:20 PM Click Here to See the Profile for vette7584Send a Private Message to vette7584Edit/Delete MessageReply w/QuoteDirect Link to This Post
it is Kemso high volume pump, my fiero store sending unit did not come with any other plugs, maybe they stopped supplying them, i just bought it. the new pump came with a plug. https://www.ebay.com/itm/Ne...p2057872.m2749.l2649
tazome
Report this Post02-01-2019 10:29 PM Click Here to See the Profile for tazomeSend a Private Message to tazomeEdit/Delete MessageReply w/QuoteDirect Link to This Post
I doubled checked the plug conections before i hooked it up, it king straight forward just take your old sending unit an find the hot wire, look at ur old ac pump , it should have a
+ marked on it. aleast mine did so i was happy then . I hope yours is the same way. if all else call the fiero store an ask for a tech helper, ther really great at that
[This message has been edited by tazome (edited 02-01-2019).]
Keen
Report this Post02-02-2019 02:33 AM Click Here to See the Profile for KeenSend a Private Message to KeenEdit/Delete MessageReply w/QuoteDirect Link to This Post
Low temp switch that turns the radiator fan on when engine gets hot
Did not have a wire going to it or the connector I would Purchase a new wire connector
That looks like it has about a 12 inch White wire lead but I have no idea where that would go
Or what color wire it would connect to
I have been using the A/C switch on the dash to force the fan on when needed
And this is getting to be a pain
JRV
fierosound
Total ratings: 286
Report this Post02-02-2019 01:02 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
You should probably start a NEW thread regarding Fan Switch problem
since this one is about the Fuel Gauge sending unit.
Click POST NEW TOPIC at bottom of Topics page.
https://www.fiero.nl/cgi-bin...&number=2&LastLogin=
Include year/engine/transmission - we are not psychic
People will then be able to jump in with help...
But the radiator fan temp. switch wire is DarkGreen with White stripe.
[This message has been edited by fierosound (edited 02-04-2019).]
