Many hub bolts are Class 10.5 or harder. Standard bolts will fit but can fail w/o warning if they don't strip when installed.
I don't have 88 data and 22P doesn't say, not even just size for this.
88 Fiero FSM Torque spec...
Three bolts attaching hub and bearing assembly. Torque to 260 N-m (220 lb. ft.) on 3C-5
bolt, hub to knuckle is 220ftlb on 3C-10
If that's right info... so I'm guess is 10.5 or harder.
Much tighter then rear hubs only get Tighten to three hub and bearing bolts to 85 N.m (62 lb. ft.)
Both specs are clean dry threads.
