  Any problem putting a 1985 Gas tank into a 1987 Fiero?
Any problem putting a 1985 Gas tank into a 1987 Fiero? by 2.5
Started on: 01-13-2019 06:54 PM
Replies: 8 (227 views)
Last post by: 2.5 on 01-15-2019 11:21 AM
Report this Post01-13-2019 06:54 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
I realize the older style tank holds less, but wondered if there are other issues? Because I cant seem to find a 1987 style tank.
Total ratings: 205
Report this Post01-13-2019 07:01 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
87-88 are same.
85 will fit.
Darrelk
Report this Post01-13-2019 07:07 PM Click Here to See the Profile for DarrelkClick Here to visit Darrelk's HomePageSend a Private Message to DarrelkEdit/Delete MessageReply w/QuoteDirect Link to This Post
Needs some reconditioning but did you see this one in the mall.....//www.fiero.nl/forum/Forum4/HTML/077419.html
You can also check a bunch of pick/pull places by doing a search at ..... www.car-parts.com
[This message has been edited by Darrelk (edited 01-13-2019).]
Rsvl-Rider
Report this Post01-13-2019 08:45 PM Click Here to See the Profile for Rsvl-RiderSend a Private Message to Rsvl-RiderEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've never seen a gas tank at Pick N Pull that did not have a big hole in the bottom. It's a shame but I guess they can't have all that fuel out in the yard where people might get hurt.
Report this Post01-14-2019 09:26 AM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
87-88 are same.
85 will fit.
Thanks. Would there be any issue using the sending unit from the old rusted 87? The 85 is just the tank.
Don Adkins
Report this Post01-14-2019 05:18 PM Click Here to See the Profile for Don AdkinsSend a Private Message to Don AdkinsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I put a tank out of an 86 in my 88. Wasn't an exact fit. Had to make some spacers that went on the straps to hold it tight. Will work though.
Total ratings: 205
Report this Post01-14-2019 06:14 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
The Fiero Store replacement would work if your 87 sender is shot.
Either unit will fit the tank.
Total ratings: 205
Report this Post01-14-2019 06:15 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Member since May 2004
post x 2
Hate it when that happens!
[This message has been edited by olejoedad (edited 01-14-2019).]
Report this Post01-15-2019 11:21 AM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
OK good my 87 works fine, even goes all the way to empty
Thanks guys
