  Electrical Gremlins Oil Pressure Guage Trunk Opener
Electrical Gremlins Oil Pressure Guage Trunk Opener by red88gt
Started on: 01-13-2019 02:54 PM
Replies: 3 (439 views)
Last post by: theogre on 09-27-2019 06:40 PM
red88gt
Report this Post01-13-2019 02:54 PM Click Here to See the Profile for red88gtSend a Private Message to red88gtEdit/Delete MessageReply w/QuoteDirect Link to This Post
Been a while since I had my 88 GT on the road (needed a clutch). Anyway, it amazes me how these electrical gremlins pop up when a car sits. I put a clutch in, cleaned up the engine compartment & she now runs & goes forward & backward. But, heres the problem the oil pressure guage is pinned when the engine is running or the key is on. Key off it's far left at zero. I took the sending unit wire off & it does the same thing, no change. Shouldn't it not move at all when the wire is off ? Sending unit plug center pin to ground does not cause the needle to move, stays far right. Key off, needle drops to zero. Now, here's the really weird thing. When I hit the trunk release button, the oil pressure guage jumps up half way. If I hold the button down the needle stays at halfway. The brake warning light on the dash comes on when push the trunk release also. The trunk release relay is clicking. The trunk lid isn't on but when pushing the button there is 12 volts to one of the terminals in the engine compartment plug. No voltage at all to this 4 prong plug without the release button pushed. Obviously, something is miswired but I've looked at all the wiring info I could find & still don't have a clue. Anyone point me in the right direction ? Thanks
Edit... after digging around in the archives, I found that Ogre addressed a similar post long ago & the brake warning light & the oil guage jump is due to a phantom ground across the guages. I'm not the only one to see this. But my oil guage is stilled pegged far left key on or running. Grounding center post (12 volt) doesn't budge it. Key off it goes back to zero.
[This message has been edited by red88gt (edited 01-13-2019).]
Report this Post01-13-2019 04:13 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
It definitely is a grounding problem. Examine the work done on the clutch replacement....there may be some ground wires still not attached. Here are a couple that are often overlooked.......
[This message has been edited by Gall757 (edited 01-13-2019).]
ChuckR
Report this Post09-27-2019 05:02 PM Click Here to See the Profile for ChuckRSend a Private Message to ChuckREdit/Delete MessageReply w/QuoteDirect Link to This Post
Did you ever find a cure for this? Mine started after replacing the temp sender. I also am having an issue where the fuel pump is not shutting off and killing my battery. I found a posting in the Ogre's cave where this run on could be caused by a high oil pressure. So I am wondering if i have a double whammy going here. Have you noticed any of this?
Report this Post09-27-2019 06:40 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Not Oil Pressure.
The OP Sender or FP Relay is bad.
Unplug 1 then if still on the other to find which one.
Rarely could be both but most time is one of them.
If sender is bad See my Cave, Oil Sensor
Gauge pegged is sender is open dead or wire to it is open somewhere.
