Click here to visit the donation page | View all sponsors
  3.4 dohc miss fires.
3.4 dohc miss fires. by ricksmastermix
Started on: 01-11-2019 05:42 PM
Replies: 4 (97 views)
Last post by: Dennis LaGrua on 02-12-2019 09:43 AM
ricksmastermix
Report this Post01-11-2019 05:42 PM Click Here to See the Profile for ricksmastermixClick Here to visit ricksmastermix's HomePageClick Here to Email ricksmastermixSend a Private Message to ricksmastermixEdit/Delete MessageReply w/QuoteDirect Link to This Post
My 3.4 dohc 86 Fiero seems to idle OK, but as soon as I accelerate, it starts to miss fire on one or more cylinders.
It's cold outside, so I want to go out to garage with a troubleshooting plan. Any ideas?
Thanks.
Daryl M
Report this Post01-11-2019 10:28 PM Click Here to See the Profile for Daryl MClick Here to Email Daryl MSend a Private Message to Daryl MEdit/Delete MessageReply w/QuoteDirect Link to This Post
Rent a heated garage???
Sorry, I just had too.
Daryl
msweldon
Report this Post01-12-2019 11:03 AM Click Here to See the Profile for msweldonClick Here to Email msweldonSend a Private Message to msweldonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Could be a failing ICM, coil pack(s), wires, or 7x CKP...
https://easyautodiagnostics...e-and-crank-sensor-1
OBD II or I LQ1? MAP sensor only or MAP and MAF? Any DTCs set?
Maybe check for a carbon fouled spark plug to locate the bad ignition circuit.
ricksmastermix
Report this Post02-09-2019 08:50 AM Click Here to See the Profile for ricksmastermixClick Here to visit ricksmastermix's HomePageClick Here to Email ricksmastermixSend a Private Message to ricksmastermixEdit/Delete MessageReply w/QuoteDirect Link to This Post
OBD I
I will check the plugs, coils and ICM first.
Thanks.
Total ratings: 313
Report this Post02-12-2019 09:43 AM Click Here to See the Profile for Dennis LaGruaClick Here to Email Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by ricksmastermix:
OBD I
Thanks.
Good first steps. Use a spark checker on each plug wire, check fuel pressure and fuel quality. Then scan to see if engine is running lean.
