Anyone know any reasons my car wants to be like -50 on the dizzy, at -10 it sounds like its running on 3 cyl but smoother at higher rpm at -30 its running smooth except has a miss at idle but will easily cruise down the free way. I know having it retarded is just compensating for something and i checked my fuel pressure at its at 37, and when i unplug the fpr vacuum line it spikes to 45. Ive never checked or changed the injectors out so im not exactly ruling them out on being clogged maybe cause a lean condition anyone had this issue?
[This message has been edited by Liam45 (edited 01-09-2019).]
30° of timing advance at idle sounds about right; I tuned my 2.8 Fiero to idle around there. That's what gave me the highest RPM / the most vacuum.
When you set the ALDL jumper to adjust the timing, you're not setting the timing that makes the engine run smoothest; you're setting the timing to a known pre-determined value, so that when the computer applies its timing corrections, the overall resulting timing is as expected.
I like where we are going with this, only issue is when the jumper is removed after setting -10 and i go a for a drive the car feels as its missing do i need to drive a bit for computer to decide the advancment? when i rev it it sounds like a 3 cyl but eventually smooths on acceleration as the rpm increases?
Setting to -30 with jumper installed is where its at now but seems to miss at idle / stall if engine doesnt catch its self in time. But with -30 it doesnt miss / sounds like a 3 cyl when going from a stop...
Have you checked the two injector fuses? Maybe you are running on three cylinders!
Yeah went through all the fuses, i tried switching out the distributor to a cardone and it idled well but lost spark between 2-3k put the old one back in and it fixed the losing of spark. the cardone also worked at -10 just idk why it was losing spark. I narrowed it too the distributor , being spark coming out of the coil was nice and hot while the spark coming from the cap was not. The weird part is at -10 the throttle was snappy on the cardone at first but it would loose spark eventually, the original distributor at -10 has weak spark unless advanced to -30....
Update been driving it to hopefully have a problem surfacee and now shes throwing a code 42........lovely def something with my spark i really dont think icm but going to swap tomorrow...
I thought maybe the timing chain had slipped a tooth so I replaced it, it didn’t slip but man it was extremely loose. But during this I checked the harmonic balancer.
Might be best to determine if TDC of #1 actually lines up with the timing mark on the balancer by sticking the proper tool (or even a plastic straw) through the spark plug hole.
And if you've changed the timing chain, make sure the valves are rocking at TDC of the exhaust stroke.
Oh no yeah I get ya I used a piston stop prior and it all lined up, I just ordered a new air temp sensor, tested it today and it’s reading very off on the multimeter, I dialed back to -10 today and it solved the code 42. The cars running eh but sensor comes in Wednesday and maybe that will help it out. Setting -10 does idle better no stalling but I think the IAT sensor is messing with my injectors idk just a thought.
