Click here to visit The FieroStore | View all sponsors
  My 2.8 developed a high idle.
My 2.8 developed a high idle. by CoolBlue87GT
Started on: 01-09-2019 11:30 AM
Replies: 9 (175 views)
Last post by: CoolBlue87GT on 01-15-2019 11:40 AM
CoolBlue87GT
Total ratings: 148
Report this Post01-09-2019 11:30 AM Click Here to See the Profile for CoolBlue87GTClick Here to Email CoolBlue87GTSend a Private Message to CoolBlue87GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
My 2.8 Formula has developed a high idle, I've read the many - many posts dealing with this.
The high idle is like 3000 rpm, The tach shows near pegged at times. ( a separate problem, thinking of replacing the tach filter with a Rodney Dickman replacement.)
Here's the steps I've taken so far.
Replaced the TPS.
Replaced the IAC. Ran the codes after installing - before starting, this puts the IAC valve in the "home" position. I could hear the IAC clicking during this process.
Replaced the EGR tube, the egr side of the tube was cracked. Replace with a Rodney Dickman tube, replaced both gaskets. I did not replace the intake gaskets yet, the old ones looked okay, will replace at some point.- - the high idle didn't get any worse or better after replacing the egr tube.
Codes found, 15 & 22
I found when I plug the IAC port in the throttle body with my finger, the RPM's drop. I've searched for a vacuum line disconnected, I don't see one unhooked. Is this normal for the rpm's to drop when plugging the port ?
I even tried reinstalling the old IAC again, have the same result.
The idle screw adjustment is still covered, no one had fiddled with that.
I sprayed the brake clean around various area's while the car was running to see if the rpm's would increase, found none.
I guess my next step will be to replace the EGR valve.
If anyone has any ideas, please post them. I am trying step by step what I can find on the forum.
[This message has been edited by CoolBlue87GT (edited 01-15-2019).]
Total ratings: 85
Report this Post01-09-2019 12:08 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
brake booster. 3000 rpm is a BIG vacuum leak. Pull the brake booster hose and cover the hole in the intake to test.
CoolBlue87GT
Total ratings: 148
Report this Post01-09-2019 12:16 PM Click Here to See the Profile for CoolBlue87GTClick Here to Email CoolBlue87GTSend a Private Message to CoolBlue87GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks, I'll try that. Where is that hose on the intake?
[This message has been edited by CoolBlue87GT (edited 01-09-2019).]
Total ratings: 85
Report this Post01-09-2019 12:46 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
CoolBlue87GT
Total ratings: 148
Report this Post01-09-2019 01:24 PM Click Here to See the Profile for CoolBlue87GTClick Here to Email CoolBlue87GTSend a Private Message to CoolBlue87GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks, that hose was connected w/ clamp. I ordered replacement EGR valve & set of intake gaskets, and a tach filter, will pull the manifold off again and replace the gaskets. I'll recheck the hoses underneath the intake.
Total ratings: 85
Report this Post01-09-2019 01:57 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yes it is. What you are testing for is a leak in the brake booster. By detaching that hose and covering the hole in the manifold, you remove the booster from the vacuum system, and the idle should go down if there was a leak.
CoolBlue87GT
Total ratings: 148
Report this Post01-10-2019 04:50 PM Click Here to See the Profile for CoolBlue87GTClick Here to Email CoolBlue87GTSend a Private Message to CoolBlue87GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I checked the hoses, the one located underneath the manifold may have been leaking, when I put the car back together, I'll double check that hose connection.
The brake booster hose was okay, I checked it before removing the manifold.
While I had the manifold off, I repainted it.
I have a few more parts on order, intake gaskets, tach filter and EGR valve. When I get these installed, I will update this post.
[This message has been edited by CoolBlue87GT (edited 01-10-2019).]
Spoon
Total ratings: 53
Report this Post01-10-2019 08:32 PM Click Here to See the Profile for SpoonSend a Private Message to SpoonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Don't forget the ATS (air temp sensor) in the air filter canistor. My 2.8 had a high idle once (3000 rpm) and a new ATS and a couple braided ground straps between engine & body and Engine to frame took care of everything. Never had a problem since plus it was a cheap repair..
Spoon
CoolBlue87GT
Total ratings: 148
Report this Post01-10-2019 09:42 PM Click Here to See the Profile for CoolBlue87GTClick Here to Email CoolBlue87GTSend a Private Message to CoolBlue87GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Spoon
Okay, great idea. I placed an order for the ATS & and a new air filter. Thank you.
CoolBlue87GT
Total ratings: 148
Report this Post01-15-2019 11:40 AM Click Here to See the Profile for CoolBlue87GTClick Here to Email CoolBlue87GTSend a Private Message to CoolBlue87GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Okay, got the engine back together, replaced EGR, egr pipe, TPS, IAC, air filter, manifold gaskets and tach filter.
Now I'm waiting on the ATS sensor and a replacement air cleaner shroud, as the ordinal one rusted out.
As it sits, I could probably start the engine now, but I'd rather have all the parts on to see if the problem is fixed.
The rest of the parts should be here in a day or two.
